If you held you finger hard against the plunger when turning the engine, you should feel it even if you don't see it move. I may be wrong however I believe your troubles are deeper than the points plunger. There are manuals for the Kohler K321 series engines online.Thanx, yer right- I didnt tell the engine, was sleepy this morning when doing research, and I didnt know either if the other thread was being watched by any gurus beside the ones there. The engine is the Kohler K 321 14 HP sits on the LGT 145. I did hold my finger on the plunger while I moved the flywheel and felt nothing. This was after the visual inspection watching the plunger not move at all. In case anyone doesnt think you can see a plunger move .020" - I can look at the clock and with each tick I can see the minute hand move ...now the tocks are a different story.... but I will try your suggestion when I get a minute, behind on my chores.
The lobe on the camshaft is worn, will have a groove wore into it. The camshaft will need to be replaced. At one time there was an after market plunge made with a wider base, looked like a rivet. I dont know if they are still available.Push rod that actuates points doesnt move, any ideas? It's not rusted or stuck, I can pull it out easily, does anyone have a parts manual they can post? TIA for any help jfox
