LI info wanted
Folks, I'm working on an LI that has recently come into my possession. The serial number is 51913, which makes it a '46. The tractor was painted green on top of the original yellow paint. I assumed it had industrial yellow under the green, it was visible in many places. Received the TC research document, it says the tractor was painted Hi-way Yellow. Was Highway Yellow similar to the ag. yellow, or something else all together? The document also list as special equipment code 'AL130', anyone know what that means?
Thanks in advance for your input-
I'm pretty sure hiway yellow was not the same as ag
yellow and would also be different than what you
would consider industrial yellow.
Someone will be on here with more definite info.
Here are the paint codes from the LI information site:
TY24353 (12 oz spray)
TY24354 (gallon)
MARTIN-SEYMOUR acrylic enamel, number 99L-8804
I have not validated these yet, but will use NAPA urethane
Hi way yellow was more like the ag yellow than any of the construction yellows/oranges of the 60's to present.
There have been examples over the years exhibited at Two Cylinder epos, etc. I would think Towcylinder or Green magazine would have access to a paint code somewhere. I would also suggest you scratch around in some obscured spot, like under the hood, etc, and see what you find. Undoubtedly there is some original, unfaded paint somewhere.
Let us know what you find!
(quoted from post at 06:13:07 01/30/17) Hi way yellow was more like the ag yellow than any of the construction yellows/oranges of the 60's to present.
There have been examples over the years exhibited at Two Cylinder epos, etc. I would think Towcylinder or [b:c0eae43b6c]Green magazine [/b:c0eae43b6c]would have access to a paint code somewhere. I would also suggest you scratch around in some obscured spot, like under the hood, etc, and see what you find. Undoubtedly there is some original, unfaded paint somewhere.
I have Dupont Dulux 43007
I have done many LI tractors and I can give you paint info if you like
My email is open Here is one that i did AL 130 Industrial Yellow Ad yellow is NOT CORRECT
