Lift arm pin damage
Status
Not open for further replies.
I cracked the housing where the lift arm pin screws into and connects the lift arm to my Ym2000 tractor. Can this metal be welded and new threads cut, or have I a bigger problem?
If there are any threads at all to screw the pin into, the parts manual shows a kit that supports the outer end of the pin, which Aaron told me at one time that he had in stock. I did almost the same thing several years ago, ruining some threads , but stopping short of cracking the housing when the pin loosened and backed out. I was`able to repair it by grinding down the pin flange to gain a few more threads, and screwing in with "JB Weld". Has held for about 6 years. You would have to check with a good machine shop about welding and re-threading.
Thanks Norm, I used the ole JB trick about three years ago too, but now I have about a 1/4 inch long crack about 1/8 inch wide. I feel like I have abused my baby.
<QUOTE author="Ken yn2000"><s>
</s>Thanks Norm, I used the ole JB trick about three years ago too, but now I have about a 1/4 inch long crack about 1/8 inch wide. I feel like I have abused my baby.<e>
/e></QUOTE>
Sounds like you could use that kit, if Aaron still has them in stock. If you have a YM240 parts book, it's listed as an option. I don't have mine handy or would give you a part #. They were about $125 for both sides at the time. Mine happened because I neglected to lube that pin when I first got the tractor, so it galled and backed out.
Status
