Lift arm pin
Detective
I have a lift arm attaching pin that is loose. How can this be tightened ? Is there a nut in the differental housing?
Thanks for your help
The nut is on the outside where you can get to it. If the pin is spinning, you have to open up the rear end to get at em for repair/replacement.
Let me guess, you have a leak there too.
Can I remove the left trumpet without taking the hub/brake assembly apart??
And "yes" I do have a leak....
(quoted from post at 19:29:58 07/30/13) Can I remove the left trumpet without taking the hub/brake assembly apart??
I guess you could take everything off at once, nothings stopping you, but it's easier to remove the tire first.
Remove the hub, then pull the axel. Makes trumpet removal real easy. Not a bad job.
Few hours on a Saturday.
Don't forget to drain the oil. :lol:
(quoted from post at 20:38:38 07/30/13) There is a nut with a cotter pin on the inside. Remove left Trumpet to do both sides.
