Lift Arm Shaft
I am ready to reinstall the lift arm shaft (3 point) on my Oliver 1600. Does anyone know where I can purchase a seal installer for this operation? The seal and the bushing for the shaft are installed after the shaft is inserted in the hydraulic housing.
Think you are probably going to have to make that. I believe a piece of 2-1/2 inch sched 40 PVC gets you pretty close, but check my memory. Clean end against the seal, glue a cap on the other end, tap gently.
