320Forest
Anyone know if there is a difference between the lift arms here and the ones at Atwoods or tractor supply of the same length? Is there some odd bend at one end etc...
Mine are flat worn out bent to snot and have already been rewelded at least once. I'm figuring I'll treat myself to new ones, I just don't want to make a poor purchase.
Can anyone tell me why my MF 50 leaking oil at the top of the lift cover, it looks like it may be coming from the stand pipe, the lift arms appear to be working fine. I thought check if anyone could point me in the right direction before I started taking apart. any info would be appreciated.
I can't say for certain with out being able to see yours but I would bet that your lift
arms are an aftermarket replacement already, originals were drop forged and are pretty
tough to bend, the ends will wear out though. the aftermarket ones are cut out from mild
steel plate with the forged ball ends welded on and quite often will bend. even though it
is labor intensive I prefer to weld on replacement ball sockets on to drop forged originals
for customers that are looking to replace their worn out ones.
