lift support pin leaking
Pknapp
my right lift support pin is loose and seeping oil.
How big a job is it to remove the axle housing and replace the pin?
It's a simple task. But heavy!
Remove the LEFT tire and LEFT side axle housing. Then pull the entire differential out (really)
Now you can tighten/repair both sides.
It is on a 1953 NAA. Ordered the parts from the marketplace last night. Seems like an easy fix.
The loader will be a bit in the way though.
Just need to remove the last couple nuts and the trumpet will be out. Hopefully tomorrow nights job.
This tractor has a howard tranny. Just wondering if this complicates the removal? Thanks.
