I posted a problem yesterday about gasket blowing out under my lift cylinder. (twice)
I am going to take it apart again. I will check cylinder for uneven suffices. can I double gasket?
As others have advised, verify new cylinder is flat & true. May try to "roughen" up the gasket mating surface to give it some tooth. Don't get carried away and un-true the surface.
one thing i dont see mentioned, when you inspect the gasket area use a known straight edge like a carpenters metal square, not a milled piece of wood , wood can lie
I still say get your gaskets from CNH because they are almost twice as thick and made from better material, or if you don't have a CNH dealer around but if you have a Massey dealer close just get the gaskets for a Ferguson TO-20. They are the same gaskets as the Ford.
