J.Wondergem
Location
Rockford, Mi.
I just bought a 48 John Deere B with 3 point arms on it. Question is does the tractor have to be moving to get the lift to work? I didn't try the lift until I had it parked in the barn. I poped the clutch in and it didn't come up with the lever. Probably has something wrong with it.
PTO must be engaged, clutch engaged and the correct blind plugs in the PowerTrol. It won't work if you have the plugs for a remote cylinder in the PowerTrol, and the bleeder screw for one way cylinder operation must be open. See your operators manual. Also check the oil level in the PowerTrol unit first.
