lights on 1030
S J P
Working on the wiring on my 1030. Is there a good modern replacement lamp that fits the front headlights that makes more light than the originals?
Thanks, Steve
I thiught they were all seal beam. If you take the block off plate on the fenders off you can add lights there. Thats what I did on my 1030.
You can replace the 4411s with LEDS if you feel rich. The pricees are rediculas. As said just add some extra lights to the fenders.Your tractor should already be wired for them and your light switch has a bright position, dim position and the last click will give you bright fronts and the fender lighting.
Loren
