Lights on older tractor
Dutchman
I'm working on the lights on my older tractor.. the shell,reflecter and glass is good, ...
I'm in need of the Hook-up .. where the wire from the outside , and the wire on the inside hook-up to.. [ not sure what you call it ]
Also one of my lights have a switch, goes from lite to red lite ...
QUESTION ; Is there anybody that sells these or makes them ??? or what can I do ??
THANKS in Advance .. for Any and All advice..
.... Mark ....
Is it a little round plastic thing (see link)? If so there are many places that carry them. Steiners, Sharps (external_link.com), and many others. I think napa might even carry them.
In regards to the switches, I think steiners also has those. They are pricy though.
light terminal
Some of those older tractors only had 8 to 12amp generators.
There were some 20 amp 12V Delco's # 1100309,1100341. And 35amp 6V Delco 1100038,1100027 used on two cylinder diesels.That work well enough making 12V just by swapping regulators.
Charging the battery, running the ignition system and three lights at 4 amps each isn't going to work. In particular if the tractor does any idling or putting around at less than 2/3 throttle.
Fortunately LED work lamps and LED replacement LED 1156 and 1157 style lamps exist.
The good 40 diode units throw a clear bright white light similar to a 15W headlight and draw less than 1/2 amp each.
Make certain the regulator is set with a volt meter instead of somebody looking at the ammeter and headlights then guessing. 13.8V summer and 14.2V winter.
Some people think that the $49.99 Napa S10i one wire alternator is the solution. However if you check the archives on this site. You will find most people get into trouble trying to make the swap.
