Richard from SE AZ
Going to make a couple of calls tomorrow about a 2N block. I have read posts about line boring a block that is being rebuilt. What is that all about and when is it necessary to do?
(quoted from post at 22:21:12 02/01/11) Going to make a couple of calls tomorrow about a 2N block. I have read posts about line boring a block that is being rebuilt. What is that all about and when is it necessary to do?
(quoted from post at 01:21:12 02/02/11) Going to make a couple of calls tomorrow about a 2N block. I have read posts about line boring a block that is being rebuilt. What is that all about and when is it necessary to do?
(quoted from post at 06:36:32 02/02/11)(quoted from post at 01:21:12 02/02/11) Going to make a couple of calls tomorrow about a 2N block. I have read posts about line boring a block that is being rebuilt. What is that all about and when is it necessary to do?
line boring is needed when one or more of the main bearing caps is damaged or replaced. The front main bearing cap is also the oil pump body and that is the usual source of a problem if there is one - not common but it does happen. Bearings can also spin in the block bore wearing the bore out oversize necessitating line boring to bring it back to specification. Simply ask your machine shop to double check that the caps are all correct - never know who was in there before you and verify the bore is undamaged. Line boring the mains alone is going to cost something in the vicinity of $200.
One other place that line boring might be required is the cam way. The cam runs directly in the cast iron block - no bearings - and the bore can become worn oversize. This is an area that is almost never checked by most guys rebuilding an N motor. Have the shop check it to make sure it is within specs. If it is worn oversize and/or the cam is worn undersize the rebuilt engine will likely have marginal oil pressure. A worn cam can be replaced with a new one for about $150. A worn block can be line bored and camshaft bearings installed. Neither is cheap but a quality rebuild seldom is and there are a lot of complaints here about low oil pressure on rebuilt motors. These motors are 60+ years old and I'm pretty confident Ford never expected them to be in service that long. If they did the cam way would have had bearings in it. Recent discusiions have suggested the camshaft bearings used in the 39-53 Ford flathead V8 (Clevite SH-21S) can be fitted to the N block if needed. Next N motor I rebuild I'm going to to do this just to say I did.
TOH
