Loader Advice
miangus
I recently acquired a MF 202 Work Bull. It came with a new Bucket that is somewhat over sized. I would like to install hay spears. The current loader has a loader arm spacing of about 32 inches on center. I would like to install some kind of quick attachment system. I was looking at a Titan hay spear frame. But its for a wider frame. Please provide your advice. Thanks.
You could use something similar to this :
https://www.vevor.com/quick-tach-adapter-c_10457/universal-quick-tach-conversion-adapter-brace-latch-tractor-attachments-p_010756355403?gclid=CjwKCAjwoduRBhA4EiwACL5RPwAcUps5xkV7f32iL6RMKob_ddFkPBqVoMZH6cA-qUl_tCsJHSIJpxoCbTYQAvD_BwE
and then put pates like this on any implement you chose to use :
https://www.vevor.com/quick-tach-mount-plate-c_10458/vevor-universal-quick-attach-mounting-skid-steer-mount-plate-0-31-for-tractor-p_010605027580?gclid=CjwKCAjwoduRBhA4EiwACL5RP9Z-g64FTV4eu3ULMC-lkQlEa6ZmHn9JJR3LTMFyEiQvoIIHzpLDNRoCFxcQAvD_BwE
I love my Titian forks with brush guard.
Check to see if you can't but a combo,
forks and hay spear.
If you want quick disconnect a good
welder might be able to modify your loader.
I would get some Westendorf, a quick attach setup, you need two male, and two females, put the males on the Loader first if the pins fit, and then weld the females on the back of the bucket,in my opinion better than a bobcat setup,but measure the Dia of your pins first to see if the Westendorf males will fit. Then build your your bale spear, or you can buy a set of forks like that Kubota got!
Not sure the capacity of your loader, but if not over 5000 lbs, I would build a setup that uses skid steer QA. If you are going to do the work, might as well have something that is really common.
If you need more capacity I would look at the euro/global mounts.
