Loader hydraulics MF202
First, if I have posted this in the wrong forum please feel free to delete it, wasn't sure where to put it. We have an old MF202 is going to have to put some work in, it needs all new hydraulic lines and various other things but it runs. To begin with the loader controls have some sort of add on hydraulics, maybe for a remote or something? does anyone know where I can find a hydraulic schematic so I can get rid of all this extra plumbing at the loader control? Thank you!
It is not clear in your picture, but it looks like the short hose end under the valve is plumbed into the return to the reservoir. If that is the case, they plugged a hose into the female quick coupler above the hand valve and ran it as the input supply hose to another valve. They would have run the outlet return hose of that other valve and connected it to the male quick coupler end of the short hose. the hand valve would have been closed after connections were made to route pressurized oil to the second valve which would allow it to operate other hydraulic items. That is basically how they got power to backhoe attachments on them. It you want that extra gone just hose the loader valve outlet port (elbow above the hand valve) to the port under the valve mount that goes into the loader reservoir. Use hose size to match the fittings, do not reduce it smaller than the smallest of the two ports.
