Per Google, Mahindra is the current distributor for Satoh tractors. Any replacement cylinder from the dealer is likely to be very pricey. However, any cylinder with matching mounting points, stroke length, and diameter should work. Pin diameter, stroke length and diameter are critical for matching the other cylinder. Tractordata doesn't give hydraulic pressure, but it is almost certainly 2000 psi or less. Pretty much every hydraulic cylinder made these days is capable of 2000 psi of pressure.I just bought a Mitsubishi satoh buck and one tilt bucket cylinder rod is bent, the main cylinder body is 24" and I believe the rod is 18", any idea if cylinders are available for this specifically or if others will work? Thanks in advance.
A good hydraulic shop or even a welding/machine shop if you're near farming country should be able to fabricate a new cylinder rod from a bulk "stick" of chromed rod.I just bought a Mitsubishi satoh buck and one tilt bucket cylinder rod is bent, the main cylinder body is 24" and I believe the rod is 18", any idea if cylinders are available for this specifically or if others will work? Thanks in advance.
www.magisterhyd.com
Why not take it to a machine shop and have a new rod made? It's a pretty simple process, and generally a lot cheaper than a complete replacement cylinder.I just bought a Mitsubishi satoh buck and one tilt bucket cylinder rod is bent, the main cylinder body is 24" and I believe the rod is 18", any idea if cylinders are available for this specifically or if others will work? Thanks in advance.
And a nice flat surface, like the cast top on a tablesaw. They really aren't that hard to straighten, as long as they aren't bent so bad the chrome plating is cracked. Almost any hydraulic shop can make a new one, like Mcrafty and Woreout say. Or they know where it can be done. steveI straightened one yesterday. A good hydraulic press some vee blocks, a piece of aluminum and a little patience.
.Why not take it to a machine shop and have a new rod made? It's a pretty simple process, and generally a lot cheaper than a complete replacement cylinder.
I see now this has already been mentioned above, I think it's a good idea too.
