loader valve question
time2plow
The loader control valve on Ford 3000 is terribly sloppy, and the valves stick.The loader is a Ford model with two sticks for controlling the loader.
Would it be better to rebuild this valve body or replace with new/factory rebuilt ? Thanks guys!
Though I am retired as a locomotive machinist/
mechanic, I was an aircraft hydraulic shop
foreman, in Army aviation, and moonlighted for
many years in a hydraulic shop.In huge earth-
movers and excavators, where the control valves
cost many thousands of dollars they do rebuild
worn out valves, usually by spray welding the
spools oversize and precision grinding them to
fit. On farm type equipment, most valves, as new,
are ground to a close fit and then lapped in,
thus a particular spool only fits the bore it was
matched to.. on this type of valve a fix
consists of putting in a seal kit, or simply
replacing o-rings if the valve is leaking
externally. Other than that, remachining and
sleeving the bore or welding the spool, and
machining it is terribly labor intensive,and
requires precising equipment far beyond what a
home machine shop or small town machinist would
have, not even including the heat treating, or
surface hardening required. It is just not cost
effective. If the actual valve is so sloppy that
it"s not working correctly, the only true fix
is to replace the valve, if its a block type
valve, (2 or 3 spools in 1 casting)or replace
sections if it a sectional valve consisting
of sections bolted togather. I would be extremely
leary of any outfit trying to sell rebuilt or
reconditioned valves or valve sections, unless
it was a dealer, or through the factory.
Slop in the handles could be addressed by using
new pins or redrilling the pin holes in the
linkage and applying oversize pins, ( or chain
links as used in some valves)
