That just a directional hydraulic valve set up to be operated with a remote mounted joystick controller. Not all valves will accept that controller set up without fabrication. You still need hoses and remote couplers. Unless there was a very good reason to use the remote controller (the cables can cause problems as they wear and/or get moisture inside them. I would mount the valve where it can be operated with the original levers and use longer hoses from the valve to the remote couplers.Anyone convert an old loader valve setup to the cheap remotes available on some websites like the one pictured?
To me, it is not uncommon for a loader tractor (or loader) to have access only on one side. If you really want to move it, I agree with Fixingfarmer, longer front hoses (down to or under the footrest with protection for them) and move the valve back between the seat and fender. Cables can give trouble on a cab tractor and even more on an open station. JMHOMy original valve setup doesn’t allow me to get on or off that side of the tractor. I was hoping this was a good solution to the problem.
Did you use one of these inexpensive cable valves from the web? If so, has it been a reliable option?I used a setup just like you show to relocate a valve bank on my bale wrapper. Easy to work with- just have to get the cables adjusted right.
Mine was from Princess Auto - which is kind of like a Canadian equivalent of Harbor Freight. It was certainly a cheapo valve, but works just fine. I always use cheap Princess Auto/Vevor valves for any of my hydraulic shenanigans - all with no issue. The only problem with some cheap valves is that they're often made in China where BSP threads are the norm (instead of ORB or NPT). No problem with BSP, just slightly less common to find a hydraulic shop that stocks BSP ends for the hoses they make. Another concern is that for a few sizes, the BSP and NPT threads are very close in diameter and pitch. Make sure you pay attention to what your valve has so you don't accidentally thread NPT into BSP and strip something.Did you use one of these inexpensive cable valves from the web? If so, has it been a reliable option?
I have used dozens of the P40 valves and they work fine. BSP is the standard in just about every part of the world EXCEPT the United States. You are going to need port adapters for whatever valve you use and BSPP port to male JIC is readily avaiible for about $7 each. Non-problem solved.I really appreciate everyone’s input. That is what makes these forums great. I think I am going to leave well enough alone for now.
I don’t know about inexpensive but my whole lifetime the jd 2555 at my house has had a similar setup cable joystick over hydraulic I think I rebuilt the top once about 2010 it works fine never have had to replace cables. If you are concerned about the quality buy 2.Did you use one of these inexpensive cable valves from the web? If so, has it been a reliable option?
When the loader is off the loader tractor do you get on or off the right side of that tractor very often? I never did, maybe it was just habit, but the brake pedals were usually still in the way too.My original valve setup doesn’t allow me to get on or off that side of the tractor. I was hoping this was a good solution to the problem.
