Pacrat
Can anyone tell me if a great bend 660 loader will mount to a case 2390 tractor loader. The loader was originally on a case 1175 tractor. Also will I have to do any adjustments. Thanks for all the help
Probably on both counts.Or it might just bolt on.Not familiar with Case tractors.Get out your tape measure and find out.
WOW, loader fit questions used to be only once a month, but now it seems like for the past three weeks they are every other day. The basic answer is no loader manufacturer made thousands of models, and in a given year they would probably make only ten to twenty models. Any given loader model was adapted to hundreds of tractor makes and models and years with different brackets, which were made in the factories by cutting pieces of steel and welding them together. You can just take rough measurements of the loader and then compare them to your tractor to be sure that it is wide enough and long enough. Then get the steel and cut it to size and weld up your brackets, or just modify the existing brackets as needed.
Depends, a 2390 should have side rails and depending on the year the 1175 may or may not. But most of the bolt holes will match up. So it will depend on how it attaches to the tractor if it will be an exact match. That model should be adaptable for any case with a 6 cylinder engine tho
Maybe, but the 1175 is the big small frame tractor, a 2390 is the big frame tractor.
a 2390 hood is much wider than an 1175 hood, plus muffler is on side rather than top.
You need to move the muffler regardless of loader. And the
frame in front of the engine is the same width, but slightly
different shape. The front casting will bolt to any engine from
a 56 400 on. For instance the wrap around weights from the
30 series won't fit on the 70 series and newer because the
front is more rounded on the 30 series. The bolt pattern is the
same at least for the 70 series and I think through the 94
series. .
Thanks RGMartin got some measurements and yes that
loader won?t fit on 2390 the 2390 is wider in rear
