Geo-TH,In
In the scientific community a person has an idea, he conducts an experiment, then publishes the results for other people to confirm or disprove. I challenge anyone to conduct my experiment, publish your results before you say it won't work.
I've read generators don't like motors because of the lock rotor amps (LRA) may be 3x the full load amps (FLA). I discovered the LRA for my 4 hp electric chain saw is at least 6x the FLA .
I conducted my experiment on a portable self-cleaning workbench (truck's tailgate), in my heated attached garage. My chain saw is a Worx 18 in 4 hp which I purchased at Sears. My genny is a Honda clone, champion 3500 watt RV 120v 30 amp out.
I carry 275 of 12 g extension cords in truck. I used the 120v outlet in garage which is about 100 ft (12g wire) from load center in house, because I don't have my genny with me today. I had to use 25 ft of cord to connect chainsaw to 120v. I measured the volts at that point and added more extension cords between the 25 ft cord and the 120v of the garage.
Here are my results,
25 ft cord, no load volts (NLV), 122.8v full load volts (FLV) with saw on 115.3v ,
lock rotor amps (LRA) 59.75a
full load amps (FLA) 9.5a
I increase extension cord lengths in 50 ft increments. The results were as I had expected.
275 ft of 12 g extension cord added to the estimated 100 ft 12a house wiring produced the following results:
NLV = 122.4v FLV = 105.6v LRA = 41.4a FLA = 9.5a
I think you can see the LRA for about 125 ft ( 100 ft of house wire + 25 ft of cord) of 12g wire is almost 60 amps, twice the amps the genny is rated at. No wonder the instruction manuals for generators say you shouldn't use them on motors.
In conclusion, 375 ft of 12g wire ( 100 ft of house wire + 275 ft of cord) reduces the LRA almost by 1/3 and the voltage dropped about 16 volts to 105.6v
So there are times when power girds are under stress, the line voltages may drop to 105v, producing a brown out. I will use extension cords to reduce the LRA of my saw from 60a to at least 40 amps if not more.
I also don't think running a universal motor on 105v will harm the motor. My concern is not to harm the genny with 60 amps.
I have been using a 50 ft, 14 g cord on saw. Only problem is I don't have any 14g cords or my genny with me today, it's at my other home in country. I will be doing actual experiments with genny, 14g cords and chainsaw when the temps warm up a little. Publish those results later.
I challenge others to conduct my experiment and publish your results.
George
George
