Locking tabs on connecting rods
Mtjohnso
I have an iH350U that I pulled the engine and pulled connecting rod caps from to inspect bearings. The engine used locking tabs on the nuts for the connecting rods to prevent them from loosing. The main bearings do not.
With Loctite and proper torque if are the locking tabs still needed?
Locking tabs are insurance. Technically no. But I would use the blue locktite as it’s the removable stuff. The red stuff will be a struggle later.
All that is needed is proper torque. The bolt is stretched a specific amount and this tension is what keeps it tight.
But if loc-tite gives you peace of mind, by all means.....
Twenty-five years ago I had a motor blue printed by a high dollar competition motor shop. I asked at the time about the pal nuts that I had noticed. He told me that they were obsolete, and that modern technology is to use the correct bolts, and tighten the nuts to the appropriate torque, so that as Fritz posted, you are going to have the tension provided by a specific amount of stretch.
The mains on a cummins 903 did not come factory with locking tabs but the rods did. The parts book showed them with the in frame kit as required for my serial number. If the parts listing shows it, pretty good idea they should be there.
Just popping in. Would anyone know where you can get new locking tabs at a more affordable price? I need some for the rod bolts for my farmall H but most sites I'm finding want 6 to 8 dollars for just 1.
