Long 2360 Voltage Regulator Adjustment
JD5210
To repair the charging circuit, a friend of mine replaced the alternator and the voltage regulator on his tractor. I am concerned with the readings he is getting at the battery. 1,000 RPM voltage is 16.73 volts and at 1,500 RPM it is 17.62 volts.
Is there any adjustment on the voltage regulator? I would like to see 14.3 volts at 1,000 RPM.
Thanks in advance for any help.
