long 360 clutch
chad9999
I need info for a long 360 tractor, the clutch will not disengage. When the peddle is pushed with the engine off the peddle has some resistance but will not disengage. Engine on the peddle is free top to bottom. I noticed a line to the throw-out bearing. This tractor has a seperate lever for the pto clutch it works fine. The main throw-out bearing goes through the center of the pto bearing. The fork moves and pushes something but the presure plate never moves Thanks Chad
