1974 Long 445 tractor. Power steering and 3 point lift problems. Tractor is very difficult to steer with a load on spear or when using loader. At times the 3 point lift will bounce up and down,also the longer it is used the tractor 3 point lift will not support the weight, the 3 point starts bleeding down to the point it will not lift or support the weight of a bale of hay any longer. I have replaced the power steering filter and fluid, drained and replaced all universal tractor fluid and cleaned the screen, did not correct the problem. always works after tractor has set idle or cooled down a while. Lift always raises and lowers with out weight on it. If any body has any advice please respond.
Thanks,
Bobby S.
Thanks,
Bobby S.
