I have a Long 360 tractor that I put a long Loader on.The Hydraulic pump for the loader is located above the PTO.The pump worked for a few days and broke.Does anyone know what kind,or brands of pumps I can replace it with. I have hooked the loader to the tractor hydraulics But they seam to be slower and I hooked the return line into the hole used to fill the tractor with fluid.The threads on this hole seam to be odd thread and is not in a good place.I think the hydraulics for the 3 point is around 6 galls per min and the one to work the loader around 9 or 10.I am guessing on the gpm. and will it hurt the tractor pump to use the loader until I find a pump.And how do you check a used one out before you buy them. The 360 Long has been a real good tractor and I would not want to tear it up thanks for any help randy
