long/utb 445
I'd check the pressure where the pressure hose coming from the pump goes into the cylinder,don't know what pressure it should run though.If the steering is not working freely you need to check the spindles and make sure they are well greased and turning easily.Also need to grease the fitting under where the battery sits.
