Looking for 3 point for 1967 731
Sorry if this is the wrong place for this kind of thing.
I'm looking to buy some parts for my tractor if someone is taking one apart.
So I'm in need of the three point assembly for my 1967 731, I would need everything to get my tractor up to speed, I was told I would also need the top plate?
Sorry I don't know too much about these things and have not had any luck at local junk yards.
I do not want to discourage anyone from taking on a project, but if you have a tractor that was not equipped with 3 pt it is a very involved procedure to add everything that is needed. Sounds like you are not familiar with the system and that will make this very tough to round up all the necessary parts. A donor tractor with 3 pt that you could remove the parts from would give you a idea and location of all parts needed. Rod.
You better give Mike F a call, and then you can bolt your engine to his rear if it is good. If there is an issue with his tranny, you will still have all the parts and peices you need, but you better get a good service manual, because the 3pt is NOT a "bolt on option", it is built into the tranny.
Loren
Thanks for all the replies guys.
(quoted from post at 08:49:11 04/25/15) Where are you located? I have the whole rear end for a 730 CK that needs a new home, I'm in central Iowa. Mike
I was hoping you'd see this if I'm honest. I tried to reply to you on my last thread but it must've gotten buried before you saw it.
I'm located in upper Michigan.
