Looking for a JD Part
nh8260
Does anyone on here know where i might get a gang axle for a John Deere disc harrow? The part number is B32003, new ones are $420!! I would take a good used one, I'm going to call Fry Equipment and see if they have one, if anyone knows where any junked harrows are please let me know, I thought i would try this before buying a new one. Mine is bent right at the end and i've got to replace a bearing so its a good time to replace the axle as well. The disc that it fits is a 1630 and is right at 12 foot wide.
Have you checked at Shoup's or Agri-supply? Spec's of disk shaft are shown below. Heat old shaft & straighten it.
Heat it and straighten it.
Heat straighten and weld it back together if broke. We have made different shafts before from old pieces when needed. Vee it ut good lay it in an angle iron tack then turn and tack again then turn and weld a bit then turn and weld half turn from that and then go to it. IF it warps some just straighten it .
