looking for help from diesel teck
marloweg
ford 2910 injector pump is leaking around the throttle on top of pump what needs to be done to fix Thanks a bunch
I had the same problem with my Case Super E pump leaking fuel at the throttle shaft. It was a simple job to take 4 screws from the corners and remove the top cover. Replaces o ring,reassembled it. Started right up, problem solved. You can do it!..Sam Womer(PA)
