Looking for main bearings for Case 350
[email protected]
It could be a G-207D DIESEL ENGINE
I am not sure early but later 188s and 207Ds had a steel engine serial number plate riveted to the block down just ahead starter and just above the pan flange.
Call, John Saeli 315-585-9826 he will be able to help you out with parts also.
This post was edited by Den N Ms on 08/30/2022 at 03:37 am.
Where can I find a Case crawler 350 enjin number?
Is it G 350 3050127?
Or G 188 D 2718372 ?
Plese help, I need to get main berings for big end
G350 is the model of the crawler and G188 is model of engine. yiou need to know if this crank has been grounded or not to order the right bearing . If you chek behind the main bearing insert usually it is stamped behind if it is standard or 0.10'' etc. jc
Hello k rans welcome to YT! You call them “big end” so you are you looking for only the connecting rod bearings? As Jean-Claude said looking for the bearing sizes on the back of the old bearings is a good place to start. Just to clarify: STD = Standard, or undersized such as 0.010, 0.020 etc. If the bearings have part numbers on the back this may be a way to identify what engine you have.
August 2022 thread, I hope he found bearings by now. His profile shows he was last seen the day he started this thread.
