Looking For Majorman
Hi Brian and I hope you are well. In 2018 I restored a very rough 1962 Dexta for my wife and
we would both like to use it for match ploughing. The problem is it has qualitrol hydraulics
and the valve makes it very difficult for both of us to get on and off the tractor. Would
the pre 1961 isolator valve fit on a 1962 tractor. MJ.
Hi MJ, how many do you want? ;0)
I have three on the shelf that I saved from some scrap lifts. Yes it will work fine but you will loose the flow control which will make the lift a bit sharp when reacting to the draft signals.
I know just what you mean. I have a spool valve fitted and that lever is just behind the gear sticks and blocks the way nicely. It is a pain getting old and your legs do not bend.
