looking for mEl (help)
Mark Lowe
I have an older (yellow) Case 970 w powershift. Put a new relief valve in a couple years ago and had trouble with hyd system this year. Replaced all the oil at that time. Oil gets hot and will not lift either cylinder or 3 pt arms with a load. Cold, it is fine, hyd oil temp went almost to red zone and even had trouble with powershift going in reverse. My mechanic also has two older Cases doing the same thing and can not figure out what is wrong. Did isolate a problem with using a single action cylinder. Tractor is worthless without hyd and 3 pt for me. It is not used much except for spring and fall. Maybe 50 hrs for the year. Any ideas? All filters are changed each year.
The first thing that comes to mind is that the pump may be getting weak, the 8 GPM steering pump, the small line coming out of the rear pump, supplies steering and brakes and the excess gallonage goes to the cooler. I would get a shop that has a flowmeter to do a simple pump flow test on both sections ( with hot oil, comparing hot to cold readings) I would like to see no more than 20% difference between hot and cold readings. Make sure the remote valves are cancelling and centering so there is no heat loads being generated there. I am suspicious of that pump as it ghould not quit pumping even when fairly hot. If the pump gets to a point that it will not raise an implement or steer without increasing rpm it's probably un its way out. mEl
Thanks for the reply, we did do a pressure test on the remotes and they were within range of what was expected, we are going to tear into it soon and see what we can find. My mechanic is stumped and has discussed it with the current Case sevice manager.
