murray moore
Is there a way to fix the splines on a crankshaft pulley?
The crankshaft pulley is loose, as well as the flat head or slotted bolt that holds it in place.
Yet, the pulley itself and possibly the crank splines are not a tight fit. About a 1/32? of play when I slip the pulley on to the shaft.
Is there a material that can be brushed on the splines, that will harden, to fill the spline gaps? Or a machined sleeve that can fit on the shaft and pulley for a tight slip fit? But it seems a keyway would be needed.
Im not sure that the slotted crankshaft pulley bolt was a good design - seems like securing it to the shaft is limited with a large flat head.
What are some options, short of trying to find a good crank and pulley.
Thanks.
Thanks.
