Lost a little weight
SVcummins
.. this ground is a bit easier so I dropped 500
When I bought my Cat it came with a full set of weights, both front and belly. As I was pulling the same equip as I pulled with my 120 horse McCormick I took all those weights off. Why pack the ground?
I agree with radial tires or a track machine just as well run light . This thing is 100 percent worthless in snow and ice but farming it just goes and with a whole lot less weight than when I ran bias ply tires with all 4 rear tires filled with fluid and it pulls better now on singles and 580 pounds of cast weight on the rear which is less than one tire filled with fluid .
They make a amazing amount of difference I can pull more with two Empty tires than 4 loaded ones absolutely no comparison my 3020 is on Bias and it pulls good to but Its got 7 front weight and max liquid in the inside duals it tips the scale at 9860 pounds the 4020 only weighs 11000
I bet that you are in a small set of probably under 20% of all tractor operators who actually adjust their weights to conditions.
It is amazing what a difference radial tires make, I have a 1066 that we bought new, my go to tractor. Started out with 18.4x38 bias duals inside loaded, then went to 20.8s loaded then back to 18.4 radials inside loaded thought that was the ultimate. But since I use it mostly for planting I switched to 14.9x46 radial duals completely empty. It will go though more mud than anything I ever had, simply amazing. Pulled through this spring enough mud that it took 2 hours to dig the mud out of a 6 row planter, not my finest hour. If I ever get another new tractor I'll stick with skinnies.
I hit some tough sod and was packing the front end
for awhile after i took the weights off but it was only
for a small section so I worked through it . I?m
always adjusting weights heavier for hard ground
and lighter for drilling and cutting or raking hay. I
had 20 front weights at one time and pulling 5x16 it
would still pack the front end with the draft control
pulling up against those tough old hay roots
These fat tires do ok In mud and amazing in dirt have to put chains on to move much snow the little tractor Is so heavy it?s a great snow pusher so I do most of the snow with it
