Lost a little weight
SVcummins
Now we can get some seed in the ground . I was going up
use the big drill but I decided the disc drill would be better
I remove just the bucket and I get less Bouncing when I use tractor to mow lawn.
Never removed the entire loader.
Makes the front end lighter. Don't know about smoother. That loader hanging out front makes for some serious bumps in a rough field.
Never noticed much bouncing even spraying range ground but this is a heavy tractor not a Little yard tractor
This one with the loader weighs just under 12000 those little yard machines they make now are no comparison .
All other things equal FEL causes tractor to ride rougher. The more weight in front of frt axle & the farther in front of frt axle the rougher the ride.
That's the reason nitrogen charged FEL suspension was developed to give a smoother ride when loader is installed.
