Loud Noise in Reverse
nates_ford
Hello, I have one of these industrial backhoes, mine has a diesel, works well but has a loud noise in reverse that comes from the transmission area. Any idea what it might be? I have a parts tractor that may contain whats damaged, thanks.
Loud noises covers a lot, could be a broken tooth on the gear. Could be a bearing. Could be the rear axle too. Pull off the top cover(gear shifter) and have a look. Jack up the rear tires and slowly rotate them around and see if you can see anything in the gear box. You might have to drain the fluid to see it. Do you have a Sherman in?
I'm not sure what I have, just an 1800 series IND with diesel, loader and hoe, no noise in foward gear, will pull a cover and look inside, thankyou.
