Low Altitude Shop Flyover
farmersamm
Actually..........when I was still stupid enough to climb a ladder for a pic
My shop is pretty much outside as well. I do have a vice mounted to a bench in a small shed but most of my work is outside.
Outside can be good in a few ways.
You don't get the toxic fume buildup that you would when welding inside.
You have virtually unlimited overhead clearance for a crane.
And, the light is fantastic. Makes seeing your puddle/joint so much easier.
Downside.........rain, snow, and direct heat from the sun in Summer.
And the wind blowing your shielding gas away!
Trick is.........spray the area down beforehand. It absolutely makes your day, when you look up, and the grinder sparks have ignited the entire countryside.
