Charner (MS)
Ford 8n history unknown. Was in owners barn 10-15 years. Said it was running well when parked. I tore it do down and completely rebuilt engine. Turned crank, pistons, sleeves, etc. When I broke it down it had no sleeves in the block. Never seen nor heard of this. I assembled the engine and cranked. Ran great. Check compression and found 1 - 90lbs, 2-90lbs, 3-100 and 4-100lbs. Ever engine Ive ever done has had 110 - 125lbs. Why? Only thing I can figure is the block was worn somewhat before it was parked and when it cranked and ran, got hot, the sleeves expanded and in effect indicated excessive wear and lower compression. What do you think?
