Low $$ Small Drill Press
Glenn F.
My neighbor gave me this low dollar drill press as her husband passed and she’s clearing out and moving out of state. Fred used this little press extensively in building radio controlled airplanes and helicopters. I plan on using it in my small dedicated woodshop.
In checking it over a little I noticed it’s pretty loud just running empty. Can this thing be quieted down with lubrication or am I just “gonna have to wear ear protection?”
The last photo shows it after I cleaned it up a little.
Thanks,
Glenn F.
I have an Enco that I bought in 1981, and excellent machine, but it's quite a bit bigger, and I run it pretty slow, so it's quiet. I think if I use the higher speeds (12) it makes more noise. I wish I had a smaller one like your just for drilling pilot holes!
The one I have is quite similar. Badged as Central Machinery from H Freight about 25 years ago. On mine the sheet metal cover-belt guard vibrated and made most of the noise. I was able to tweak the little strap-retainer piece that holds the cover down and that stopped most of the rattle and helped a lot. Still seems a bit noisy but for the occasional use it gets I can tolerate it. I think it’s pretty much the nature of beast for a small inexpensive China drill press.
I bought one that size that was built in Tywan 30 years ago for my home shop. At that time when I was looking if you wiggled the chuck they had a lot of play. I looked at every place that sold tools in Fort Wayne and found one that was tight. After I paid they brought one out in a box. I said take it out of the box so I can check it out. The owner said why, they are all the same. I said ok give me my money back. He took it out of the box and it was sloppy. They loaded the one on the floor in my pickup. It runs quiet enough for me. I have a large drill press in my tool shop that is gear driven that will call for ear protection.
Thanks,
Glenn F.
I have one like thast a co worker sold me for $35 back in the 90s. He was into wood working and had bought Shop Smith and was getting rid of some stuff. It has some play in the drill shaft so precision is not it's thing. I got a nice Craftsman bandsaw from him cheap(replaced all wheels) and used it when building RC aircraft kits.
I picked up another floor-standing press several months ago because I couldn't pass up the price. Another oriental clone special, but if the motor runs the rest is so simple it can be made to work easily.
One thing i noticed was the noise level, and removing the belts just about killed all the objectionable noise. Most of the noise was generated between the belt/sheave arrangement and the stamped metal belt cover amplifying that noise. Lubricating the sheaves, managing the belt tension, and damping the sheet metal covers against vibration can help a LOT.
It's small and fairly low-power and capacity, but having a second drill can be really handy when setting up the shop for "Wood Mode" and keeping one auger or Forstner set in one drill and a different tool in another drill can really speed up serial production once the parts are in process. The last time I ripped, cut, planed, moulded, and drilled parts for porch railing it worked out really well to keep the chips flying and ballusters stacking up by the dozen for making up new rail sets.
Glenn,
Some of these little drill presses are just noisy. I'd check the belt cover and pulleys first, especially if anything is rattling. That thin stamped cover can make more racket than you'd expect.
If it's still loud with the belts off, that might help narrow it down. If the noise goes away, it could be the belts, pulleys, or cover. Still loud, you're looking at the motor or spindle.
Lube what's supposed to be lubed, but oil won't quiet a rattling cover.
Thank you to each of you for your responses/suggestions. What a nice group of fellows we have on this site! Fred was extremely skilled at anything mechanical, and took very good care of his tools and equipment. He could bring anything back from the dead and have it operating better than new in short order.
I still need to take a serious look at the little machine but I did rule out a few things. Holding the cover down (dampening) while running makes little if any difference. Motor runs quietly with belt off. I believe both pulleys are tight. It is currently belted for “low gear.”
As stated, I’ve probably spent less than five minutes analyzing the machine but there does seem to be a slight bit of lateral movement in the “”shaft” the chuck fastens to. Of course my preference is precision tolerances but a little movement for my intended purposes is acceptable.
Thank you again to each of you.
Glenn F
If your unit is a common oriental press they are all quite similar, and there are only a very few bearings in the entire assembly - Only four not counting the motor.
If you can find a manual for your model it will be more definite, but the assemblies are almost clones regardless of the name on the piece.
I have the floor stand version of that Tool Shop drill press. Sold by Menards. I've had it for about 25 years and it has been pretty good for the price. Plus it was a Christmas gift from my wife! It's done anything I've asked of it and is actually very quiet.
FWIW, a nickel says the upper and lower driven sheave idler shaft bearings are 203KDD (6303PP) and the spindle bearings are 201KDD(6201PP) and 204KDD (6204PP) or equivalent Conrad type ball bearings.
If the quill tube (#47) is not sloppy in the bore of the housing, the play is likely in the spindle (#51) and those bearings can be checked. If the tube is loose in the head, there might not be much to be done other than to pack the head with heavy grease, replace the seals (#46) and hope for the best.
I have a similar Taiwanese floor press and a little TLC made it acceptably quiet and stable. It's not a Walker-Turner press by any stretch of the imagination, but also not terrible for a lightweight unit.
