LP fuel problem
Jared K
On a 1958 JD 730 LP, when you turn on the vapor valve and then turn on the switch to turn on the fuel strainer, there is propane coming out of the air intake; you can also hear it bubbling through the oil bath as the vapor comes out. Is this a problem with the gaskets in the converter or somewhere else??
Thanks in advance
your pressure reg. is gone...repair parts can be bought at any LP dealership or Deere...probably has a Century on it which are eazy to repair...Kent
