m 3-point hitch
dray s
i bought used 3-point for my m not sure how it mounts or if i got all parts to mount and can i still use my draw bar appreciat any help
It depends upon they manufacture of the 3 point. The one that I got on my SMTA allows me to use standard drawbar. The only problem I have is that the 3 point lift arms will hit drawbar before the implement goes down enough.
It mounts to the inner axle housing brackets. With Saginaw the original drawbar bolts to the 3 point. No problem with implements not lowering.
The hitch is self explanatory if you have the brackets on the axle housings. You can't use the original drawbar brackets because the 3 point uses them. As mentioned the original drawbar bolts to the 3 point Saginaw, you remove the original attachments from the drawbar. Some 3 points have their own drawbar. If not you have to attach a one piece drawbar to the sockets in the lower 3 point arms.
Here are a couple of pics,(If this helps???)
The first one is of course WITH OUT a drawbar,The second is mine WITH the drawbar.
thank you very much for the pics that sheds light on things getting a look at one mounted and all the info guys
