M and Super M Carburetor
Not sure what Jim is talking about, but Ive swapped many M carbs for SM carbs, and the only changes was to do something about the choke rod connection. The SM is on the inside, not the outside. In fact, one of my Ms has a 450 carb on it.
(quoted from post at 15:37:36 03/19/16) Will a Super M carburetor work on an M?
Yes. Direct bolt on. The Super M carb should have a metering stem with slightly larger holes than the M carb., and the venturi in the SM carb might also be larger, but you should be able to adjust the SM carb enough so your M will never know the difference.
