m and super m clutch
tim w
i have a 1944 that we are puting a super m engine in and the super has a 11 inch clutch i belive and the m clutch was on 10 will the super m clutch work with my m input shaft and throw out bearing
(quoted from post at 23:54:53 03/01/09) i have a 1944 that we are puting a super m engine in and the super has a 11 inch clutch i belive and the m clutch was on 10 will the super m clutch work with my m input shaft and throw out bearing
Yes. The size difference is from 11 inch to 12 inch.
If you have the original belley pump hydraulics in the tractor the SM size clutch will hit the reservoir housing unless you remove, or switch to a housing from a late M or SM.
