m and w govenor
The Brute
I have a 41 M farmall I pull in the out of field class. I do pretty good as is, but would a m/w governor help more?
i have a M&W governor on my 44' M and it is a lot more responsive then the stock and if u get a stiffer spring for it can turn a lot more rpm's as well.
To say it won"t add a pony without setting some parameters is inaccurate. I have a Super M that when I got it had about 51-52 hp MAX. Not at 540 but that was all I could get. With a really good governor and carb adjustment I got her up to 62 hp. The original governor was so worn the weights were hitting the case. If you have a good tight governor with a good spring what you may gain with an M&W is response time and you should reach peak HP at a higher RPM.
