Ellis Kinney
I am probably going to need to replace my exhaust manifold this winter. I have welded the pipe back in twice with nickel rod and the cast manifold breaks loose from the nickel just below the weld. I am thinking really old brittle cast. Anyhow--- I have never replaced an exhaust manifold before and am really scared of snapping a stud off in the process. Should I warm it up and melt candle wax around the studs?? What is the best gasket?? I always read the pros and cons of using gasket sealer and which side to use it on. Also torqueing information. The engine and head were rebuilt in 2008 so it has been apart not too long ago. All advice and information will be appreciated. Thank you, Ellis
