There is a coupler where half is attached to the shaft coming out of the transmission of the tractor and the other half is on the shaft on the pump. When you lift the pump into place the halves have to be lined up correctly to make it go together.
I found it. Had brain freeze there for a few minutes. Lost it when I dropped the pump out of salvage tractor. Thanks.
