I want to thank to all that replied regarding the M-H 30 pistons.
It is not the original engine. No serial number plate. It is really weird I removed timing gear cover to replace the oil seal and found that when you align the camshaft and crankshaft timing marks the valve timing to piston is off a punch mark on the crank gear is the correct timing. This is a weird engine I will pull the engine and have it bored to 0.20. Again, thank for all the replies
