M hydrolics
bubsdad
I have a log splitter I run with the hydrolics off my M.
the pressure is not much and the hydrolics keep shutting off. Even when the splitter returns to rest it kicks off the pump.
Is there a way to boost the pressure, raise the kick put pressure or both??
if you are using the belly pump to drive the splitter, the later pumps only produced 800-100psi of pressure. the earlier pumps were lower pressure, somewhere around 600 psi or so. i ran a splitter of my m for a while, just tied the rod back. about the only way to get more ummph is to run a big diameter cylinder on the splitter. now, i use a pto driven pump on my farmall b to drive the splitter, about 2250 psi pump. splits a whole lot better.
