Terry Smith
A friend has bought a M and is having some problems with the wiring and has these questions.
Is it a positive or negative ground?
6 volt or 12 volt?
Can a Alternator have a external voltage regulator?
Any help would be appreciated
It can be any of the above.
The unit was sold as Positive ground 6v with generator and either a voltage regulator if 49 or newer (not sure on exact break date) or a 4 position light switch that manually regulated the charge rate, and a cutout relay.
If it has an alternator, it is probably 12 volts, and it can have a voltage regulator seperate from the unit. Many early alternators were made like that including all the major auto manufacturers. If it is not working, Use the following link to get it right. JimN
Bob Ms wonderful diagrams
6 volt positive ground from the factory but that could have been changed in the 60 plus years the tractor has existed.
Older 12 volt alternators DID have external voltage regulators.
