M john deere axles
mcline5
Hello new to site. Restoring a m john deere and rear axle stubbs take different nut . Left side is 11/2 right is 2 1/4. Is this normal or what's the deal. I belive all seals will work for john deere catalog doesn't show right final. Thanks
(quoted from post at 09:36:00 02/04/22) Hello new to site. Restoring a m john deere and rear axle stubbs take different nut . Left side is 11/2 right is 2 1/4. Is this normal or what's the deal. I belive all seals will work for john deere catalog doesn't show right final. Thanks
I think you made a typo and meant to write 1-1/2" and 1-1/4".
Early M's had 1-1/2" axle threads, at S.N. 10,456 they changed to a 1-1/4" thread.
Your tractor must have had an axle replaced at some time and has an early serial number axle on one side and a later serial number axle on the other.
MC welcome to YT! It looks like you got your question
answered, I am quite in the dark most times about
those green paint machines. As you can likely tell by
my handle red paint is more in my wheel house. Not
that we do not welcome posts of all brands here in the
Tractor Talk topic setting I thought I would let you
know the following. There is a ..John Deere.. topic
section here you can post your real JD ..head
scratchers.. over there and will likely get the best
answers. You can get there by using the ..Jump to.. or
..Hop to.. drop down bar below each post. And for
starters I will post a link below that will get you there.
Luckily you are getting a model that does not require
all the extra workout for your right arm to run the
clutch. ; > )
John Deere topic section
