Under the seat...4- 1/4-20 bolts hold on a small plate. If your 445 has been upgraded to the tel-o-flow system, there will be two levers coming out of this plate. If that is the case, put the lift arm control lever in the neutral position and remove the plate. The oil level should be 3/4" below the top of the casting when the lift arms are in the lowered position. This system uses automatic transmission fluid.
